Dashboard needs to come off 91 Volkswagen Cab
dashboard doesn't light up, so ive decided im goling to take it apart and get to the problem myself.
but the only problem is i can't find any information on how to take the dash out.
any ideas?
thanks so much!
off of this car:
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines :o
It will be a fault with your light switch with dimmer function. The striker contact from the dimmer has worn or is out of adjustment, you can take it apart and respring it to make it work....make sure you take it apart carefully as there is a nice micro sized ball bearing that easily gets lost.
***PM for all your powder coating needs***
shamstar said
It will be a fault with your light switch with dimmer function. The striker contact from the dimmer has worn or is out of adjustment, you can take it apart and respring it to make it work….make sure you take it apart carefully as there is a nice micro sized ball bearing that easily gets lost.
the dimmer still lights up certain things though - do you still think thats the problem?
