dash trim by air vents
(In Topic #122668)
My vinyl covering has come loose where it overlaps the air vents on the top of the dash by the windscreen. Someone recommended some clips, as gluing hasn't worked. Has anyone got any ideas where I could find suitable clips to do the job thataren't too obtrusive?
have u tried using somthing like hot glue from a glue gun cos if u try something thin like super glue it will just soak into the dash board material its like compressed card board lol or the spray glue might work that u use for speaker enclosures carpeting then put somthing weighty on it to let it set
Life Member
Welcome to the site, I see it your first post so stick around and make yourself at home!! 8)
The parts that you require are sold by Crazyquiff and the link is below. Scroll down and you'll find the dash vents.
Dan
http://www.golfmk1.co.uk/Items.php?cat=ALL&group=DASH
(and they work, I've got them in mine! :wink:
Dan
Thanks guys. Sorry I've been out of action or a few weeks so only just caught up with these. Do the grill inserts fit a mark 1 cabriolet? I noticed it said series 2 on the website. They look to be just the business! I managed to drop a piece of plasctic about 5mm wide and 30mm long which I was trying to make a clip out of down the third air vent from the left and it's got lodged right down at the bottom!. I can't get it out easily, and everything seems to be working OK so best left alone I suppose. These grill inserts should stop me doing that again!
Life Member
They do fit cabby versions, got them in mine. They aren't solid or meshed so stuff could drop down them again but they do keep the plastic from blocking the verts and the windscreen clear.
