cutting compound
(In Topic #95899)
cutting compound
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
T-Cut isnt a good option if you need to deeply restore paint, it takes hours on end. there is a more abrasive option called safe-cut which is like rubbing compound toned down a bit.
ive just realised that whole paragraph didnt help at all, so i would personally use rubbing compound (sparingly)
1983 Golf 1.3 Driver:
Steve_Matthews said
Oh - and anyone reading this with a metalic car - DON'T EVEN THINK IT - all you'll end up doing is ruining the laqure on your car!
its true… i had a citroen AX for a while (in a summer, just to make a few quid) and i used it to get rid of grubby lines around the badges, it just killed the shine after only a couple of minutes, wouldn't come back either, so i was forced to cut through the whole laquer to get back to paint :cry:
Pete :wink:
if so this link from Eastsidevw may help
http://www.eastsidevw.co.uk/forum/viewtopic.php?t=7819
if its body work you are after then G3 will help remove scratches from paintwork or there are other strong products to bring paintwork upto new
Finny said
If ive read this correctly its for alloys your after aint it?
Yes mate there for my perelli alloys
1983 GTI-Black
what finish is there on the wheels?
Peddersgolf said
G3 it is called
Pete :wink:
and its made by a company called farecla, they do a whole range of cutting compounds, g4 for high cured solid paints (i use that on freshly painted cars when flatting and polishing) g3 is much coarser and must be used with lots of water so it doesn't burn the paint off (ive done that too ops: ) and im sure they do a range of other products which might include wheel stufff
Finny said
Damn I must of been pished when I posted that…………never realised yer only down the road in the land of the monkey hangers
Think there just an normal alloy finish where about you like maye
1983 GTI-Black
Think Ive heard G3 would do to polish them up……………….whats up with the alloys? they just dulled or something?
