corrado interior into my mk1!!!! any help
(In Topic #127562)
i want to put a corrado interior into my mk1 golf (when i get it) can i acheive this without alot of modifications being done. any help will be awesome thanks for looking guys
so… you would need to cut the outside leg on the back of each seat and make it about 20mm shorter an weld it back on again
now the back seats… dont try it unless your willing to butcher both the mk1 seats and the corrado seats
i did it with mk3 vr6 seats and the problem is, is in the back ot the rado they fold down in a 2 and 1 system but in the mk1 golf they all come down together. PLUS the rado seats are about 2 inches wider.
i welded the frame of the mk1 seats to the top of the back mk3 seats which was the easy part..
i had to butcher the foam of the mk3 seat bottoms and then basically cable tie the leather to the mk1 frame… looks good when done but if you are in the back and dont have your belt on the seat base wobbles lol…
so to recap. the fronts are as easy as making 2 tubes a little shorter and putting up with the slide feature being hard to use but the backs are a totally different kettle of fish
hope this helps
booze and boredom, the greatest mix
T
