Complete DIY Home Respray
(In Topic #117056)
Just looking for some advice from people/anyone who has done a home spray job. At the least i'd like to do the engine bay, interior and underside myself with a view to doing the outside depending how this turns out.
Two basic questions firstly.
1. Should I stick to celly or use two pack? I have heard 2k contains isocyante and is poisonous but reading on here a few people have sprayed this at home? Can anyone give me correct info from this plus the pros and cons?
2.Does anyone have a good online parts supplier for painting equipment (stone chip, masks, overalls, gun wash, sandpaper etc)
Simon
Oh don't just do the bits you mentioned , do the lot
Marc
Cellie's crap! It's porous
I've read you can get non-isocyanite 2 pack, and an alternative might be acrylic.
Marc
primer is pourous though.
I would love to do 2 pack at home for every repair, but to be honest, it would take me a week to setup, and then another week to pack up after, when i respray the whole car in one hit i will do it in two pack, so if thats what you are doing then do it.
But for 2 pack you will need.
2 x compressors @ ?250 each minimum
Airfed mask @ ?120 min (wilson)
Air breathing filter bank @ ?140 minimum (kestrel from sprayguns direct)
Air breathing low toxic air hose @ ?80
Some sort of extraction @ ?160 min (I have a 1500cfm extractor)
An airtight booth to work in so the iso cyanate doesnt escape into the rest of the garage this can cost as little as ?40 to make
SO the addition cost to using celly is… (saying you need 1 x extra compressor)
?790.
Also do not do it in a garage thats attatched to a house, as the iso's get through walls, The need for extraction is essential too.
Or you can go for celly,
which yes it isnt as durable, however, if you look after it, its fine.
But as you are going for metallic, its the celly laquer thats the crap stuff, the 2k laquer is far superior. But for solid non-metallic colours then celly is fine, get a good sealer on it after then a good wax to protect it form UV and celly looks lovely,
also, 2pack isnt even paint, its molecular structure is more like plastic.
Anyway,
Any other questions, just ask
Marc
