Clutch job !
(In Topic #81924)
Clutch job !
Finally got my Mk1 GTI running, needed a new fuel pump, fuel tank, fuel filler neck and the fuel systems cleaning out, she now starts on the button & sounds pretty healthy ! only problem is that the clutch is slipping badly. I know its an engine out job and I have had a quick look through the haynes manual - anybody got any advice/tips for this job, gonna be two of us doing it and I'm hiring a engine hoist.
Got most of the way through replacing the clutch on my mk1 GTI, but I had real trouble getting the gearbox back on coz the clutch pushrod fowls on the hole in the clutch it is supposed to sit in.
I understand it needs to be dead central - anybody got any tips on how to make sure it is ?
Also should I replace the clutch pushrod seal while i'm in there ??
dragon said
Hi all,
Did you buy a clutch with a centring tool in the box? Its a little plastic circular thing, that you put into the clutch while you're tightening the bolts. Because the VW clutch is the 'wrong' side of the flywheel, normal clutch centring tools don't do it.
dragon said
no mate, I brought the clutch kit from German Swedish and French ? should it have come with one then ??
Some do and some don't. I bought a LUK clutch and made sure it came in the box - I opened the box at the counter to check. Ironically, I think I've now lost mine, I have a clutch job to do again swapping one over, so I need to have a look for it. If I find it I'll show you a piccie, I'd have let you have it except that I'll shortly be needing it! I am sure someone else will be able to help you out, though. Its a plastic thing and can only be worth a couple of ? at the most.
rebuild in progress....
http://cgi.ebay.co.uk/FRANKLIN-TOOLS-CLUTCH-PLATE-ALIGNMENT-TOOL-SET_W0QQitemZ200051319974QQihZ010QQcategoryZ30922QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or just be persistant,and get it inline with your eye.takes some practice,but can be done.
ops:
And I guess some luck…
