Clipper kit fitting
(In Topic #130774)
Clipper kit fitting
get some pics up so we can see what you got so far.
The kit usually consists of front and rear arches and side sill covers.
These are screwed in to plastic fittings that correspond to the shape of the holes.
The arches are also riveted into the bumper section too.
There is a gasket that fits partially around the arches and a strip that goes behind the cill cover.
Have you got the necessary plastic fittings to fit the kit on with?
myfirstcarwasagolf said
Its the plastic fittings that worry me…..all I have currently is holes in the metal work :-(
Hi Fella,
what have you got missing?
I can point you in the right direction for a body seal kit if you like.
I got one for DEK on here.
It's sillicone and not plastic, in black.
Pm me what you need and I will see what I have got in my bookmarks to link you too.
A lot is in the USA so doubt will be here for Sat, although DEKs stuff only took a week.
There should be a couple at the front and rear to take the front and rear arches.
I would not advise fitting without the proper fittings.
Thanks dave
sending you a pm.
