Clay Sticks
(In Topic #83015)
Clay Sticks
Just wondering if any of you have "detailed" - i hate that word! So for all you traditionalists out there…
have any of you cleaned your car using one of these "clay sticks" at all?
Are they as good as they`re cracked up to be?
What`s your findings with them?
Any recommended brands?
:dontknow:
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
Clay bar kits are for removing overspray/tar/small surface contaminants etc,and will give a very smooth finish…even if you think its good already.
Ideal for old original paint or paint that hasn't been correctly looked after by means of a good cleaning/polishing/waxing process.
I currently have a christmas offer on the meguiars clay bar kit.
Neil.
It is important to remove road tar and tree sap from the paint FIRST. Clay bar cannot remove these heavier deposits without becoming over contaminated itself.
Use plenty of "quick detailer" which is similar to spray wax - or simply using a lot of water as you would wetsand paint.
I prefer to only run front to back motions along the lines of the car - that way if it scratches, it won't be as bad as if rubbing in circles or across the lines of the car. Roll the clay bar often to keep a fresh side on the car. DO NOT LET WHATEVER YOU LUBRICATE THE CLAY DRY ON THE CAR - it is a pain to remove later.
Then polish, wax, seal or whatever you sacrifice to the :twisted: DETAILING :twisted: gods.
The first time I did it was a religious experience for me. Smooth as silk paint!
