Cabrolet roof leaking
(In Topic #96595)
Unfortunately when left stood in heavy rain the water appears to get blown up the drivers and passenger window and over the top on to the seats - nice!!
Is the seal between teh windwo and teh roof replaceable - am I missing an easy fix??
<a><img></a><a href="Login to a private Photobucket.com album
can also lubricate the seal with some silicon to ensure its soft and flexible.
when door closed, window should be up nice and tight against that seal and the seel will slightly roll/buldge over.
welcome amd if yaa can get some pictures up.
1988 1.8 carb Golf Clipper
I have the same trouble. Keep it indoors else with a half cover (halfords cheap as chips).
How do you adjust the windows/doors? Is it a DIY job?
cc
doors can be lifted but i think theres a seal on there which can be replaced.
Chairman
This seals wear on the far left and right edges and allows water to drip through the mechanism which holds your roof down.
I think VAG still do the seal, about ?120 + Vat though
Probably be worth looking around first.
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
to adjust the closed position then you can loosen the strike pin adjust and the retighten. while you looking at this check the strike pin still has its plastic collar on. If its broke then you may want to replace anyhow. Parts avail either from VW direct or fleecebay.
As for replacing the seal, fairly easy but you would have to check on availability/price. Simply remove one screw near windscreen and slide out. If it doesnt slide the pull out but be care full not to break plastic tab at the stricker end. Could get awkward if someone has gunked up with sealent if hood has been replaced. When you put new one back lubricate with wd40 and then slide back. Just before the screw hole lines up put a small amount of sealent on final cm and pull into place and tighten the screw.
pic of striker with collar
when prowler gets his computer cd ready, you may want that as well.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=255855&highlight=#255855
djheap22 said
also check out this post, the online vid clips may help a little.
You just beat me to it!!!
I went and found the link, and when I came back you'd stolen my line!
djheap22 said
great minds think alike
Both drive cabbies……..nuff said!! 8)
