Cabrio roof cable where from.....
(In Topic #141977)
where is the best place to get the cable for a cabrio roof, the one that pulls the roof material in to the car that runs across the top of the boot
cheers rich
The roof is in good condition, only 5 years old, but the cable is visible down the side above the petrol cap, and looking rusty.
It doesn't look like it can be tightened anymore, so I'm sure the previous owner has tightened it as much as possible.
Also, how easy is it to replace?
Ta.
Chorttle the "roof guru" should be along soon to advise some other possible sources :-)
You can get them from VW i think but they are VERY expensive, i have no problems with the new one i fitted to my old clipper from BAS
http://www.car-hood.co.uk/content.php?nID=2&cID=42&pID=4356
Rich
1.8T CABBY
1.8T CABBY
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
Re: ..
lagger said
Got mine from crazy,s….
… and how easy/difficult to fit?
There is not a lot of room where you tighten it inside the car but take you time and you will be ok..
You should have a look at the guide on here first though if I were you.
Give it a go youll be alright…promise..
its a little tircky to get into bolt where you release each side but not too bad, i did one a few weeks ago with arf333 on his cabby to release the tension cable before it went to respray, we found it easier with the roof half up or down if you know what i mean. you should then be able to pull one end put and pull it all the way out from inside roof tabs itself. Getting new one in should be too tricky its just getting the ends back into where you put the nut back on
cup of tea and patience and you should be fine :-)
There is more than likely a guide on here
1.8T CABBY
1.8T CABBY
I've read the guide by Ross on replacing the whole roof, but it loses me on the cable bit so if there's another guide on just replacing the cable that would be great.
Looking now …
(Also the roof above the doors is perfect on one side, but set an inch too high on the other. It's not letting in any water though, so one job at a time eh? )
Im sure ive seen the set (both sides and the back cables) on ebay for about £25
http://www.ebay.co.uk/itm/VW-Golf-MK1-Convertible-Tension-Cable-Set-/160783748476?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item256f754d7c
Thanks for all your help guys. Just looking for an idiots guide now … and a sunny weekend.
