Cabby rear window seal?
(In Topic #98581)
Hi, i have a cabby. The rubber seal around the rear window appears to be fine but the little plug that fits in the hole at the bottom is missing.Where can i get this from? I have had a quick look on GFS website and couldnt find it.
Help would be much appreciated as i dont want to have to resort to a mug to catch the dripping water :roll:
Cheers everyone.
Cheers everyone.
Hi,
myns not original roof so perhaps I have the same problem but no little plug, and cant see anything on ETKA. Are you sure there is one?
All they have done on myn is put the split at the top, that way less likely to allow any water in, also its sealed in as well.
1988 1.8 carb Golf Clipper
I assume there is supposed to be something there becuase the last time it rained water dripped through the hole and now my parcel shelf is damp. Might be a bluetack jobby until i find a better solution.
Guest user
I have the rear window out on mine at the moment as i am fitting a roof and the window seal is one piece with not cut, slot, or gap. I would assume its been cut but perhaps someone can advise.
Mine is one piece, ordered a new seal from VAG when I had my hood replaced. Maybe someones cut a different seal to fit the rear window?
checked with early-1800 and his is one piece, so looks like myn has been cut or replaced with non original when the hood was recovered.
Ok thanks guys looks like its a one piece seal then. Will have to get a new one or improvise something.
