Cabby Electric window
(In Topic #83975)
Was wondering have any of you with Cabbys come across a snag with the drivers door window mechanism.
The rear of the glass jams on the seal on the roll over bar as the window is winding up.The top of the glass appears to be in too far.It has Elec Windows and have tried adjusting it etc.
Any feedback would be fantastic.
Keep up the good work
Tanx
Does your's have a bolt at the bottom of the door for in and out movement of the window?
Ther are more adjustment inside the panel for parrallel fit fron and back.
Hope this help.
Rob
Audi A4 1.9TDI - Gone
Its a factory Electric Window set up,lucky me.
Have already tried adjusting the aft guide rail in/out etc,even elongated the two holes to get some extra movement.Took it out and bent it a bit to increase the angle but nothing has worked.I also put a bigger load on the inner seal strip hoping it would push it out enough.The seal on the roll over bar is sitting tight.
Im getting a bit frustrated with it now. If anything it should be the other side giving trouble cos the car was lhd when I got it.Now its rhd so the drivers door now would have been the pax door and shouldnt have done as much work.
