Bulkhead Replacement help
(In Topic #92903)
How easy is it to do?
Did you need to take the engine out?
Where do we get the bits/bulkhead panel from?
Any help gratefully received
1983 1100 C
1983 1100 C
Any idea where I can get the bits?
1983 1100 C
1983 1100 C
Where the accelerator cable has pulled through you can get a smallish preformed piece of sheet metal that actually only needs glueing to the bulkhead as all the force applied by the cable tries to push this plate against the bulhead (it is fixed to the engine bay side). I have often seen these pieces on evil-bay. As far as where the wiper motor mounts, I would say that any competent body shop should be able to mig/tig weld a repair piece into your existing bulkhead. Methinks replacing the whole bulkhead would ott.
If not on evil bay for the clutch cable repair, maybe Crazyquiff:
http://www.golfmk1.co.uk
has a suitable piece
or Hadrian:
http://www.carpanels.co.uk
Good Hunting from up Jessun Herrod way
Super
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
Yradave says relax.
07792646786
07792646786
yradave said
No it is the large panel underneath the bonnet and the plastic tray that is in the engine bay. It is directly above the pedal assembly. That piece is the lower mount for the windscreen isn't it?
bulkhead
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
Re: bulkhead
the auto version does have a hole for the clutch cable but on mine there's a gromet in it!!opentopvw said
ideally you want to get an entire bulkhead from an auto doner car as they didnt have the hole cut out for the clutch cable, so dont have the rot,you would be hard pressed to find a decent bulkhead from a non auto as they all rot in the same place, all mine have a repair plate over that section, apart from the auto :roll:
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
a hole
foxymk1 said
this one? i know its a bit OTT but i like the pic
That's the one - I saw the pic and just thought holy smeg - mega work ahead!
Re: bulkhead
So what's the best place to get that from? Is there a good dismantler that volks would recommend? :?
1983 1100 C
1983 1100 C
