Bonnet opening on bumps.
I keep getting my bonnet opening when i hit potholes or large bumps.
I have a set of koni adjustables and lowered Eibach springs fitted, i wonder if it just cause its harder suspension, My bonnet catch worn or can it be adjusted.
I have tried pulling it open when i shut it but it seams solid.
Its doing my head in esp when i am on dual carrage ways as i keep waiting for it to flip right open sometime and smash my windscreen and roof, and its also a pain having to slow down till i find somewhere to stop.
Thoughts guys.
I'd say it wants adjusting myself, does it shut fine?
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
Shuts easy and perfect  :dontknow:
does the catch move much? the bit on the front panel? get someone to operate the release and see if it moves much, may need lube on it.
Regards Volkswarren
As above. The springs pulling the catch across to the left might be weak / slack. Take the radiator grille off and have a good nosey and play around to see what's what. I used a couple of long springs out of a brake shoe fitting kit to replace mine and hooked it into the holes on the slam panel! You don't want to carry on with it popping up all the time.
In my last Mk1 I had the bonnet fly up when I was doing about 55mph. It made a mess of the bonnet top corners and wrecked the hinges, but didn't break the windscreen (it hits further up but didn't even damage the edge of the roof). You can also look through the air intake slats to see where you're going to pull over :lol: It had wedged over the wiper arms and they had to be removed just to get the bonnet back down! Don't rely on the safety hook to stop it blowing up, it might not always work!
Thanks, sounds like good advice, i will check and do all that, dont want a flying bonnet situation.
When it has unclipped in the past, luckily enough the safety hook kept hold of it.
