Blocked rear Drain hole
(In Topic #100148)
Since then i've spent my day at "work" checking the drain holes.
Front two are clear and operating correctly. Rear passenger side is clear as i sourced it from the back of the wheel arch and gave it a blow "so to Speak".
Drivers rear is well blocked, so i ran a piece of flexi cable up there from the back of arch, stops dead about a meter in, NO JOY
I'm considering pulling or cutting back the headliner to attack it from where the pipe connects to the drain hole. Gonna replace the liner in time.
Don't wanna remove the liner completely for one blocked drainhole, where abouts can i make a small incision to access the connection for a quick fix?????
I have no idea where to Cut, help!!!
If it ever stops raining i'll have a feel about and update.
nik
woZa said
Have a feel around - should be able to feel where the flexible tubing connects to the metal drain. It's about 20cm behind the front of the rear 3/4 window and about 10cm in.
Where are the rear drain tubes then, and , more importantly where do they terminate.
Bloody car is doing my head in
:x
