Black rear decal for mk1 golf
(In Topic #122733)
wanted some advise. my boot decal/vinyl on the boot of my mk1 is not looking too good. now i am looking into buying a new one and found on ebay that is a four piece boot decal, now is that what they normally are….a four piece decal?
heres what i have found:
"Ebay link to decal"
has anyone bought one off ebay? or is there a certain place you guys would advise on getting one?
all advise would be awesome
thanks
Dubsy
1983 Mars red MK1 Wagen.
richievr said
that is how they all come, bit of a pain to fit, but take your time and it will be fine..
i got mine from volkswagenstickers.co.uk and the fit is pretty damn good!!
ah thanks Richie!!!!
Will do, you also have to take the rear window and seal out don't you?
The BIG secret is to get half a bucket or a bowl full of Very CLEAN warm water and dump a smidgen squirt of washing up liquid in it (Fairy Liquid - its better for your hands init????)
Now sponge the slightly soapy water all over the bottom of your boot lid and apply the bottom piece. That way you can slide it properly into the correct position….it will NOT stick to the boot lid immediately giving you plenty of time slide it around to adjust its position. If it starts to stick and you're not happy with its position, peel it off gently - it should come off quite easily - and add more soapy water. If OK sqeegee the water/bubbles out from under the vinyl with a wad of Kitchen Roll or a towel (don't tell the wife/mother….). Don't try too hard to get rid of all the "lumps"..rest assured they will disappear as the soapy water evaporates (and it will!).
Then do left then right pieces likewise and finally the top piece. Each upper piece should slightly overlap its lower neighbour by about 5mm…that way you don't get a gap if the sun shines (AS IF) and shrinks the vinyl a tad….the pieces should be designed to overlap slightly so don't try and butt joint them
When all is dry (about a day this time of the year), you will be able to fold the inner exposed edges of the vinyl over the edge of the window aperture and then refit the rear window…job done
Trimsport do a very satisfactory reproduction of the vinyl stickers - don't forget there should an additional strip across the back of the hatch just above the lower edge
http://www.trimsport.co.uk/html/badges.html
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
