BBS RM 001 alloys restoration, from beginning to end
(In Topic #141638)
Hi mates,
Just finished restoring my BBS RM 001 alloys, please feel free to ask if any of you is doing the same.
Also if any of you knows about BBS RM 001 center caps I'd appreciate it as I am looking for them.
Well now I can say that the process is complete for they're already mounted in the car, no air leaks so far, which is not always easy.
I'll post photos when I lower down the car next weekend, will look so much better lowered and with appropriate center caps..
they are the right ones for rms
if you mean the center caps they are for RMs but not for this model, when you fit the cap you can put a finger between the cap and the wheel, i think the caps are for RMs with bigger offset.
BTW the center caps are for sale
hahaha in the nutella I put the bolts to get cleaned with vinegar and coke, it's like a magic potion!!
car lowered, still some margin to get lower adjusting camber
result:
Promise better pics, iPhone camer at night… no good
result:
protect the threads?
when you put the lips on it's better if there's nothing on that surface, it can cause air leaks as it won't stick so well, this has to be sanded to make sure the surface is totally uniform so don't think it'd be a good idea to paint that area
Even silicone in that area it's bad, the silicon would have to be spread on the joint between the outside barrel and the lip, as the photos show, anything in that surface also can change the torque of the bolts, so again nothing in that area but rough metal sanded :wink:
no probs good luck with the wheels post a pic when they're finished
