Anyone done the tailgate surround decal?
(In Topic #127822)
Like which piece to start with and what order after that, oh and soapy water?, heatgun?
Not done decals properly before so any help muchly appreciated :wink:
Greg
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
Next up, glass out! I used about 15 old table knives out my mum's kitchen draw, and essentially worked my way round prising the glass out, leaving each knife in as you go. If you do it right, the glass will just "pop" out.
Next, heat gun to remove the old decal. Trust me, this is pain staking, but it needs to be done. Then use some intensive tar remove to remove all traces of the glue/decal.
As for fitting, its pretty simple in comparison!! lol. basically soapy water in a bucket, and sponge it onto the tailgate. Next up, remove the backing of the vinyl sticker and lay it into place. You've then got a little while to move it around/finalise position. Then use a cedit card or similar to push out the air/water bubbles. This takes a while…but it does work, trust me!!
The order for applying the decals is: Lower, Sides, Top. This is done for the same reason as overlapping roof tiles, water droplets drain down and over the decal joints.
Once done, allow this to fully dry out, then its time to replace the glass. Use a piece of cord or thick string, along with plenty of washing up liquid as lube, and "pull" the window seal back over the tailgate lip.
Job Done!
1982 Golf GTi - Mars Red and totally stock!
