anybody know how to change a carpet
(In Topic #94523)
cheers fellas!
1989 1800 golf karmen convertible on webers
1972 vw beatle 1303s
2007 bmw 530d msport
2012 ford transit (work horse)
1992 vw golf mk2 gti
get a carpet set off newton commercial and its pre moulded, pre cut an its a perfect fit, not cheep at ?140 but the ammount of time it save fussing around cutting and glueing its 100% worth every penny
the only tricky parts is the side bits under the dash but other than that its simple
thats what i would suggest tho
hope this helps
sam
1 take front seats out. this is done by undoing the bolt under the front of the seat removing the rail covers from the rear and slide the seat back as far as it will go.
2. take the handbrake cowl off the handbrake.
3. remove the plastic slides under the rear seat by removing the screw at the front.
4. remove the door sill plates these clip over the lip so you need to pry them off. now the rear carpet should come out just watch for the small taks holding down round the edges.
as for the front
1. remove the centre console 1 screw at the rear on the passanger side. 2 screws to the dash and one behind the gear stick. remove the gear knob which is just screwed on.
2. remove the door sill plates if you havn't already (you have to remove these for the rear aswell)
3. there are a few press on clips under the dash i think theres 3 one either side and one behind the centre consule.
4. slip the side bits of carpet in the footwells away from the main carpet which are taked to together.
now remove the carpet same thing again watch for the taks around the edge.
now in true haynes fashion fitting is the reverse.
hope that helps.
can anyone suggest a way of getting it to stay?
or why it would no longer stop in place?
Twitter Manager
blans said
so glad i've taken it out can now find out where the water was coming in!!
finding the water leak can be an endless task, mine was coming in from more than one place 8O
Still haven't stopped it coming in yet, think i only need to get my front sunroof drain holes sorted now & that could be it :pray:
Good luck with yours :wink:
