Another Cabby Leaky Roof Story
(In Topic #101555)
Chris
As for the dark brown standing water, my old cabby had that under the carpets when it had been leaking. Not sure why, but is it possible that it's just picked up old muck from the carpets??
Even if this isn't much help, it's a free bump back to the top - someone might know more!
Good luck :wink:
Leaky cabby
Chris
sometimes the tops of the windows are too low and don't meet the seals on the roof properly.
Also water can get through the plastic plugs that insert into the frame that hold the rubber top seals in place.
yes roofs do become porous over time, but i would check the drain holes under the bonnet inside the scuttle panel as suggested.
you can also buy seals that fit between the rubber sections that meet against each other when the roof folds down.
I had a really bad leak and had to do all the above.
I glued a piece of neoprene rubber to the header seal and the last seal of the roof. This worked for me.
