Aligning doors
(In Topic #94736)
Aligning doors
Hi All
Just wondering of theres any way to re-align the doors on my 3 door as the passengerside door is to far forward and the drivers door needs a tweek aswell, is there a way to re-align them myself or would it be best to take it to a body shop.
Wayne
Wayne
Mass produced cars like the Golf usually means any door will plop straight in the hole . :dontknow:
You can fit packing washers behind the hinge and bend them slightly for a better fit . Pattern wings can make the door seem out of line .Worn hinges can cause the door to drop . So find out why first then have a go , it's cheaper .
try loosen of bolts on hinge then lift or drop as said above packing a washer then tighten up should work
<a><img></a><a href="Login to a private Photobucket.com album
