Adjusting the hood...?
(In Topic #108995)
Just went out to my cab as i thought the interior light was on.. it was.. and has been since yesterday so you guessed it flat battery!!
anyway back to the original reason for this thread. lol..while i was sitting in my cab (in process of checking to see if i had any battery life left) i noticed that there is a small gap that runs along the top of the drivers side window..i tried doing the window right up and the gaps still there..
Is there some sort of adjustment on the hood or on the handles as id like to get that sitting water tight because if i go to wash it its going to let in water!!
Thanks for any help!
Scott.
the door panel.
Robbo said
I'm fairly sure that you can adjust the closing height of the window from behind
the door panel.
cool, i'll wip the door card off and have a look in that case- anyone else know if the closing handles are adjustable to adjust height of hood?
chortle said
yep Robbo is right, take of the door card and you will see the bolts, you need to let the rubber seal gently curl over the top of the glass when the window is wound up, don't bring them up to tight against the glass.
Cool, thanks for the advice! will sort that out sometime this week!
