aargh got a leak
(In Topic #121786)
COTM Team
aargh got a leak
think ive found it though looks like its getting in from where roof meets top of window at the edges, looks like rubber seal not been fitted correctly at some point and has lifted at the edges, its either that or the roof isnt tight enough, i checked the rubber seal and it looks like its been fitted with sealer and not glue.
does anyone have any suggestions for sticking it down or other ideas on leak
best regards
chris
8)
Life Member
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=63414
COTM Team
hi guys, thanks for info, the hood is 2 years old with no tears or damage, the rubber seal thats lifting at edges is on winscreen part of car (if that makes sense) where the roof meets the screen, gonna have a better look today and post findings, if it helps it only leaks when it rains lolchortle said
If the water is getting in as stated then you will need to adjust the windows so they fit properly, the seal should press gently onto the glass and slightly depress forming a seal, there is also a little shaped seal that fits between the first 2 roof rubbers. Also you may need to refix the first seal that presses against the header seal to make sure that is water tight. As metioned the foam seal gaskets that fit under the seal retaining strips, these are often a source of problem. Lastly how old is the hood and whay material is it? Vinyl becomes porous over time and lets water in that way.
chris
COTM Team
