A watery morning - need advice
(In Topic #74401)
Anyhoo, i've had a look under the bonnet and the scuttle has about 4 inches of water in it. I imagine the rain drain holes have clogged up with crud. So, my question is, whats the best way to clean them out, and where are they?
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Anyway, you can take these out to 'empty' them and give 'em a damn good clean.
Problem solved.
'83 Mars Red 1.1 C
I've been trying to find where the water has been getting in thru and its tricky. On the left side (as you look at the front of the car) i've found an unplugged hole in a chassis leg, and i'm not sure if water was getting into the cabin thru there (see pic). It looks like it should have a bung in it. It was covered by a piece of red gaffer tape - hence why i never spotted it. There's something in there but i can't tell what. Any ideas about this? Can i get a bung for it ?
The other thought i had was to extend the rain drain tubes with 1/2 meter long bits of old tube so as to let the water drain almost to the ground, to stop it trickling down the interior of the car? apart from it being harder to un-clogg them, would this be a good idea?
'83 Mars Red 1.1 C
'83 Mars Red 1.1 C
The water seeps over the lip to the hole and down in to the footwells, i think before it would reach any other hole. Make sure you get a scuttle cover if not one fitted already?!
The holes in the upper surface of the chassis legs in the engine bay should be covered by strong cloth tape, which was applied by VW before being painted.
If it's missing, all the water that drains out of the scuttle area, through the rubber drains above, will go into the chassis leg, and will fill up the area beneath the pedals, overflowing through holes in the panel behind the pedals, soaking the carpet and soundproofing.
'83 Mars Red 1.1 C
