Yay! Another MK1 Cabby GTi (DX engine) cold start idle issue!
(In Topic #198714)
1991 MK1 GTi Cabriolet Rivage. Original engine, it's standard.
Cold start idle is very low. 600rpm, wanting to cut out and stall low. As it warms up it becomes progressively better until it sits around 950-1000 quite happily.
Idle fluctuates ever so slightly, maybe 25-50rpm maximum.
Idle speed is slightly intermittent, i.e. one journey it might be 950rpm, on the way back 1050rpm
The AAV seems to be working (squeeze the air pipe when cold and the engine chokes, when warm no change)
Timing is spot on, ignition and cambelt
New rotor arm, cap, HT's, plugs and coil.
The idle screw seems tight and it does adjust the idle, I've done CO2 by ear but I'm popping to my local garage to get onto their equipment. Should it read 1-2% on idle?
Any help appreciated.
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
check everything over as per this thread, but ignore the 16v specific bits:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
rubjonny said
aye about 1.8% is what i woudl like to see.
You the man. Thanks!
