Would you believe it? A DX not starting
(In Topic #158144)
Ive got an '83 DX engine GTi. The damn thing wont start unless I hold the throttle open and then dies as soon as I let the throttle go.
The flap in the metering head is nice and loose.
Fuel pressure seems good (as I found out when checking and getting my eyes and face full of unleaded)
Ideas please cos Im going to end up firing the bloody thing soon
Why did I start this
Taylslad said
Has it run recently or has it been off road? I found with mine some time reading up on k jetronic invaluable, good description on here and then start with basics, injector test with fuel pump relay swapped over for constant running. Check for spark/ timing, chech all vacuum connections tight, wiring to cold start valve etc, earths, I made a checklist and worked through it.
It had been unused 2 years before i cleaned it all up put new gaskets on and put it in the car.
I think the injector test is the only thing remaining.
That said ive noticed a small, perfectly round hole on the inlet mani near to the butterflies. Anyone else got one here?
Also, when cranking i can hear a knocking noise which sounds like the flap in the metering head bouncing about. Is that normal?
On top of the metering head near to all of the fuel lines, there is a metal tube which looks like it goes in towards the above flap. Is anythin meant to be here?
The tube you mention sounds like the hole you poke a 3mm Allen key down to adjust CO mixture.
Is it still running on the 2 year old petrol?
Birtymeek said
May as well end the topic here. Did some more digging around in the engine yesterday and found that the cylinder head has cracked
Sorry to hear that mate. Are you going to get it repaired or do an engine replacement???
In the process of sorting another head which Ill have recon and ported. then Ill have bottom end rebored and increase displacement
Old engine - fuel + spark but split head
New engine. - mechanically sound but no fuel or spark
