wont start at all ?
(In Topic #102470)
wont start at all ?
i have tried 3 metering heads on it and the last one was from a running car so i think i can rule that out.
new fuel pump fitted,new injectors,new warm up reg,new coil,new dizzy cap etc,new relay,tank drained cleaned,new fuel filter.
i dont know what else to try and i cant afford to keep throwing money at it.
anyone else had these symptoms and managed to fix it ?
If warm start only
First thing would be to measure system pressure during starting. What basically happens is the battery is turning the engine, the voltage drops, this makes the fuel pump pump at lower pressure and its possible not to produce enough pressure to open the injectors.
If cold start
Check the 5th injector and thermo time switch, loads of info on this on the forum (search should reveal).
Whether it's hot or cold it won't start without the squirt of the easy start
widget2k4 said
thanks for the answers
Look at both problems then. If the cold start valve works, it should squirt in enough fuel to start the car with, even if system pressure didn't open the main injectors. (Won't run for long tho!)
What would cause the voltage drop ?
widget2k4 said
Ok will check cold injector
Poor battery; poor wiring to fuel pump, ie anything from the condition of the wire, connectors, fuse, etc.
are you sure your earth straps are clean AND rust free?
i cleaned mine rubbed back with coarse sand paper car started first time!
and the starter was definately turning faster too
my 2 pence 8O
