Won't start; possible fuel pump/relay problem; help please!
(In Topic #110869)
Hi,
Can anyone help with this one, please?
I have a Mk1 1983 GTI 1800. It's been off the road for a while, but has been running, albeit quite lumpy. Went to start it today & nothing doing. I ran some checks recommended in Hayes manual. The plugs are new, with a good visible spark & the engine is cranking over fine. It looks like no/insufficient fuel getting to injectors. I have replaced the fuel filter - as I thought some dirt in the tank may have got through - but still no joy.
My checks led me to suspect either the fuel pump, or the relay. I haven't been able to check the pump - as space is very tight & can't jack up the car at the moment.
The relay is part 321906059D. Reading some other posts here, it seems like the relay should click when energised by the ignition; it doesn't. Also seems the pump should make a whirring noise when ignition energised; it doesn't!
As the pump is so difficult to get at [& expensive!] my next move is to replace the relay; does anyone have a spare for sale?
Before I do that, I would appreciate any advice from someone who's gone through the same problem. Please post any comments.
Many thanks.
Many thanks for your prompt help. I'll give that a try tomorrow; I don't have any spade connectors, but I guess I can get some at an auto shop…. do they need to be a special sort? - or will any do; as long as they fit in the large holes?
Thanks again..
Thanks…. the fuel pump fuse is 15A; will that be the right size for the wire link fuse too?…. or should I wire in something smaller?
paul_c, Cero,
Guys; many thanks for your help. I bypassed the relay with a fused lead today. Result; a slight whirring noise from the pump & the engine started first time.
Just need to get a new relay now…..
Many thanks for your assistance - much appreciated!
