White/Blue Smoke, Using Oil, Inlet Manifold Very Oily?
(In Topic #123003)
Obviously the car is buring oil due to the smoke, and the need to keep topping up the oil, but what is casuing the oil to be in the inlet manifold? Any help would be really appreciated.
Has anyone got any idea what else has gone? :x
Anyone had anything like this?
I've had the head crack tested and rebuild with new valve stem seals, replaced the head gasket and replaced the rocker cover but it still seams to be sucking oil into the inlet manifold. I checked the airbox and the flap was covered in oil :dontknow:
Any ideas anyone?
Is there anything that could be blocked that is causing the oil to be sucked out
***PM for all your powder coating needs***
That will tell you if theres a ring issue. If one cylinder comes out lower, drop a bit of oil down the plug hole and do it again. If it goes up then the rings are the problem. if it doesn't then it's the headgasket.
If the figures are all within about 5% of each other than the problem is likely valve seals/guides.
Jon.
