Which 2L block?
(In Topic #97252)
Which 2L block?
Has had some headwork but i am now thinking of replacing the bottom end with a 2L can someone tell me which 2L engine type will fit the k jet head? Will i need to change anything else or is it a straight forward swap?
Also i was only told my engine is a blueprint by the previous owner is there anyway of telling? The block is blue and the pistons have codes stamped into them but i cant see any difference on the cranks etc.
Thanks for any feedback,
For the blueprinting, you could weigh each piston and each conrod, and see if they're the same weight (i.e. piston 1 = piston 2, 3, 4, and conrod 1 = conrod 2,3,4). This would give you an idea of whether it's been fine tuned or not.
Not sure what else to suggest really - have you had it running? Would it rev freely higher than standard (6500rpm +)?
HTH
Rich
Thanks for link!
