Wheres the aux belt?
(In Topic #118237)
3 belts on the vehicle - fanbelt, cambelt, assuming the last one is the aux belt.
How do you tighten or replace this aux belt?
no such thing as a fanbelt, its an old term.
timing belt, alternator/waterpump belt (can be called aux belt) and last of all power steering belt
Read somewhere that tightening the aux belt could improve idle - looking to find out which belt aux is, and how to tighten.
set the tension so theres 5mm of deflection. i doubt it will improve your idle though unless its way loose or tight!
Where did you read this (do you have a link to another forum?) and did it definitely relate to the Mk1 Golf? The golf doesn't have an 'aux' belt, at least its not normally called this, so I am wondering whether its for a different car.
Its possible that the advice on poor starting related to checking the cam timing, ie the cambelt might have slipped a tooth.
The alternator/water pump belt wouldn't affect starting directly, although it might have an indirect effect if it was so loose to slip all the time, not spin the alternator and allow the battery to run flat.
Yeah, its not the alternator belt, which would leave only the timing belt.
Ill try and dig the thread out.
Its the cam belt aka timing belt, if you search on either of these terms, you should be able to find a thread which details how to check the cam timing. Incorrect cam timing would affect general running, as well as starting, though.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=40352
