Where to buy DX Valve Shims?
(In Topic #203956)
As the title really, can anyone point me to where is best to source valve shims for my solid tappets?
The hardest thing I found was working out what thickness the old one was as the writting had worn off so I had to use a micrometer to check the thickness. I have made a note of what I fitted and what's in there so next time I can work out what I need with out having to remove the cam and shim to read what's in there, there is a special tool to remove the shims with out removing the cam but I don't have one of those and it's only 8 bolts holding the cam in.
You can also get them from here.
http://www.vwspares.co.uk/g1other.php
Last edit: by mark1gls
