what to change with head gasket
(In Topic #145883)
what should i also get done so far i think;
timing belt (cam belt)
auxiliary belt
head bolts
is there anything thing else someone mentioned a water pump is this a good time to do it. it there anything else i should do whilst engine is in pieces. Cheers kev
Re: what to change with head gasket
Cheers kev
Could change water pump while at it but if you are may aswell go whole hog on water side ir thermostat, fan switch and flanges on head known for cracking.
Would be a lot cheaper to do this all yourself using a Haynes manual.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
I'm not an expert but I'd say while the head is off it's a good chance to check/replace any worn valve guides and valve stem oil seals, as well as maybe lapping in the valve seats. I've got a hydro head so also replaced the hydraulic tappets. These things all needed doing on mine as it was smoking like a b*****d and a bit 'tappety'. Yours may not need them done immediately, but guides/seals aren't too pricey and after all, when will you next have the head off.
Paul
cant find the flanges on the head known for cracking. any part numbers or links to websites please cheers kev
Granty said
Hi mate, had to do mine last year.
Paul
how would i know if its on hydrolic tappets or not? cheers again
"Is there anything on this car that I cant be arsed to change"?
While you're in there you may aswell do it properly.. so get a full head set which will have every top end gasket, should also have new stem seals in there too.. when the head is skimmed maske sure they lap the valves in and fit new valve guides at the same time as skimming it..
Got an internal micrometer? measure your bores, they miight want a hone and new rings. Big ends and mains? Oil pump? the list goes on and on - but look at it this way - the more you look after it the longer it'll last!
spend the money on doing it right and the car will love youi for it, a d reward you with many years of trouble free dubbing :mrgreen: :mrgreen:
Take it easy ; )
