What Manifold
(In Topic #136033)
What Manifold
Re: What Manifold
richb said
Hi all i have just bought a mk1 1.8 GTI
Whole car or just engine??? I'm guessing, just an engine. What year and bodystyle, they have different manifolds according to a year split approx 1983-1984.
richb said
…..to go with the convertiable
Do you mean to install into? Hasn't the convertible already got an engine??? And what model and year, ie clipper, GTI, GL, GLS, etc etc
richb said
i have been told that there are different types
Yep, just counting the big block engines there's at least 4 different types, which vary according to year/model. Basically pre- or post approx 1983-1984; and either GTI or non-GTI.
richb said
and mk2 1.8 GTI are different
Mk2 exhaust is irrelivent, unless you sourced a replacement engine from a Mk2, in which case you'd need to know to remove and throw away the Mk2 manifold. It doesn't fit the Mk1.
To be sure, look at the downpipe, is it a 6 bolt fitting or a C Clamp fitting - that's the difference.
Also, the GTI system (all of it, including the manifold) is very slightly bigger diameter, so a non-GTI won't do.
