What engine do i have?
(In Topic #147223)
im ordering several new parts and need to know what car they should be listed for (gaskets, seals, etc…)
im assuming its the 2E from a mk3 golf gti but im not 100% so ive turned to the pros.
Cheers in advance
Corrado bottom end.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
its not a 3a if that helps narrow it down.
is there a cast date stamp on it.
is that a round plug for the front as some have the breather here and some vent out the rocker. also i think there is a difference in height in some 2.0 blocks so you may be able to measure it
not sure what seals you need
im leaning towards 2e since it has the mk3 type oil filter housing (look at top bolt, its shifted to the left compared to mk1/2 type)
if it does have a crank sensor hole then its an agg or ady, the crank sensor is right down the bottom of the block next to the gearbox end. i can see a casting mark there but cant quite make out if there is actually a hole
