What coolant? g12 plus plus? halfords advanced?
(In Topic #125686)
Hi all…
As the title really, changed my radiator switch and thermostat as it didnt have one!
Also, would a better coolant result in a cooler running engine?
Many thanks
Many thanks
Nope. Just running water, would result in better cooling, but corrode the engine a bit, so you need a little bit of coolant. AFAIK The newer style one's advantages are longer service life.
I think it should be Glysantin G05. I know that Univar sell it. It contains a hybrid corrosion inhibitor package with nitrites, salts of organic acids and silicates. G12 ++is VW name for Glysantin G40, G12+ is Glysantin G30.
on second thoughts Comma (www.commaoil.com) do G05, its called Extreme G05. It will tell you the local stockist.
Life Member
