Waterless coolant
(In Topic #200802)
Is anyone using it?
http://www.evanscoolants.co.uk/
Has anyone used it? Is it any good/worth the money?
Do a search, lots of discussion about it. Cost is pretty high, supposedly lasts forever, but you'll have to re-fill everytime you disconnect cooling system, and will still require a top up…
I'll do my research, thanks
Waterless coolant
Hairyarse said
lhasadreams is using it in his, I'm sure he can give you some feedback Mike
Yeah that would be handy, I'm a bit torn on if it's worth it or not. If it works as advertised it has some distinct advantages
Website Manager
Waterless coolant
So some 4000 miles later I have been really pleased with it. The engine temperature remains more constant. The water temperature reads a little higher but the oil temperature is about the same.
The advantages for me are that the engine is better protected from corrosion as there is no water to corrode the internals and there is less stress on the water pipes as it does not pressurise - you can take the cap off the expansion tank even when fully warmed up. Finally it is filled for life.
There is a downside if you get a leak as you need to capture it to put back in once you fix the leak or you have to buy some more which could get expensive - for this reason it would make sure that all your hoses and radiator are in good order. In an emergency you can top up with water but you then lose the properties of the waterless coolant.
So like everything there are positives and negatives !!
They are the same reasons that I'm considering going that way, I just wanted to avoid being sold some magic beans - so to speak.
