water wheres it going?
(In Topic #122637)
mini old skool of course - 1310, lightened and balanced bottom end, fast road cam, MG head, Megajolt + EDIS, stripped out interior
Metro Autograsser - built myself
with the heater on full hot it should constantly deliver hot air, if it doesnt the head gasket needs looking at.
First of all though you should check the pressure of the expansion tank cap. if you dont have a tester replace it with a new one.
Lookin at your initial repairs for overheating it would seem likely the head gasket has failed.
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
My thermostat went, and although my temp needle didnt go over half the water boiled and poped the cap of me expansion tank :-(
after that i was loosing water, changed thermostat and expansion tank cap but was still going through alot of water, it does sound like headgasket mate, mines in being pressure tested skimmed and re fitted now.
1.8T CABBY
1.8T CABBY
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
water
jammie dodgers rule
