Water pump leak
(In Topic #72237)
Water pump leak
Anyone got any thoughts on this or will it mean new water pump?
I can try gasket first as cheap! Anyone know if it should be the 7 hole or 8 hole type. Don't think I can see without stripping alternator belt, pulley etc down first
When we bought the Gti there was a big puddle under the car (after running it a bit). Knocked another ?100 off the price - still using the same water pump after 3 years !!!! It just stopped leaking, so maybe (?) yours will do tghe same?
If I remember correctly exchange water pumps are not too expensive from GSF ?? You'll need the new gasket anyway, so my thoughts are that the whole job should be done once….if the gasket does not cure it you will need ANOTHER gasket and do the job again……if you see what I mean.
1984 white s2 golf gti , 2006 golf gti
woky said
its prob the pump and be carefull getting it off them bolts will snap like carrots ! :?
TIP: When fitting a new water pump to the housing, use stainless-steel bolts (look up "Fasteners" in the Yellow Pages) - if you break off even one bolt when opening them in the future, it's time for a new housing…
The ?19 one looks like it's been stuck together by kids in school with play doh. (oh and it's brasillian crap)
98701 PLIERS-WATER PUMP GENERAL USE 5.95 Add
17050 WATER PUMP-BQ G1 1.1 >12/83 19.75 Add
17050 WATER PUMP-BQ G1 1.3 8/79 >12/83 19.75 Add
17057 WATER PUMP-COMPLETE G1 1.5 & 1.6 Carb >7/81 22.50 Add
17057 WATER PUMP-COMPLETE G1 Diesel & Turbo Diesel >4/82 22.50 Add
17057 WATER PUMP-COMPLETE G1 GTI/GLI >7/81 22.50 Add
17058 WATER PUMP-COMPLETE G1 1.5 To 1.8 Carb 8/81 > 19.00 Add
17058 WATER PUMP-COMPLETE G1 Diesel & Turbo Diesel 4/82 > 19.00 Add
17058 WATER PUMP-COMPLETE G1 GTI/GLI 8/81 > 19.00 Add
17058A WATER PUMP-COMPLETE VW/AUDI 1.5-2.0 PETROL+1.6D-1.9TDi 81>** 24.50 Add
17200 WATER PUMP SEAL G1 1.1 / 1.3 1.25 Add
This list from GSF shows a ?22.50 item
17057 WATER PUMP-COMPLETE G1 GTI/GLI >7/81 22.50 17058 WATER PUMP-COMPLETE G1 1.5 To 1.8 Carb 8/81 > 19.00
Simon
'83 Mars Red GTI
It's this one! GSF have just confirmed back to me.
Life Member
I see no point in replacing with less than original parts esspecially when so little in price and considering how many parts are no longer available we should get those that are.
I understand this may be a little late now though.
