Water Pump
(In Topic #204752)
I had a problem with the bolts snapping off on my thermostat housing so ended up removing the water pump. Now the pump is off I am wondering if it is worthwhile replacing it with a new one ? I know on a modern golf this is a good idea when you change the cambelt. As far as I know it is the original pump and I have no problems. Is it a good idea to replace it or a waste of money ?
Car is a 1.8 GTI DX
Many Thanks,
BigMoose
With the older VW's the pump is run of the alternator belt and is so easy to get to.
I've still got my original VW fitted and it's still going after 275,000 miles and 28 years!
Will pop the old one back on then. Think mine is original but not done that mileage !
http://www.eurocarparts.com/ecp/c/Volkswagen_Scirocco_1.6_1981/p/car-parts/cooling/car-cooling-parts-and-car-heating/thermostat-housings-gasket/?369440050&1&698dac12c011b8d8e564f96741c3674062f9e757&000574
