warm startings a pain
(In Topic #72370)
Needs to turn over a bit when warm.
I know this could be accumalator or leaky injectors, anything else? I don't seem to have a fuel leak!
Peter.
1980 1600 GTI, daily driver.
Turned out to be the Hall Sender, local auto electrician sussed it, repaired it and it's been perfect ever since. Mind you, at ?70 to repair it I should have got an exchange dizzy !!!!!!!
Peter.
Trouble is the only way to see if your accumulator is faulty is to have the system pressure tested at all operating temperature or renew it . The only stumbling block being the cost i think they are over ?130 from VW .
Chudd….
Domain parking page
I think it just floods the engine, only supposed to work in cold.
Way to test is to unnbolt it, disconnect wires and bridge fuel pump relay for one minute.
No fuel should come out as long as it's electrically disconnected
Also mentions taking of the lead off the coil. Surely this isn't neccasary as I will have the ignition on but I won't be cranking the engine so it's not gonna start?
Anyone done fuel pump relay bridging experiments?
Anyways, seems like it would be easiest to test thermotime switch first. get engine nice and warm, disconnect leads to 5th injector and start the engine. If engine starts good then it's the thermotime switch. Could put a voltmeter across it but whats the point?
Gonna try thermotime switch on the way home from work.
Standby for results…
Peter.
The Accumulator
The accumulator is the first of the components in the fuel system after the pump. This unit has an important role to fill in the operation of the Bosch K Jetronic system.
Its first job is to help smooth out any pulses in the flow of the fuel, this is achieved by passing the fuel through a series of baffles and into a chamber giving it slight capacitance and a much smother flow. Its other and possibly more important role is to maintain pressure within the system when the fuel pump has been switched off; this is achieved by the accumulator spring and diaphragm pushing against the fuel.
For the duration that the engine is running, the diaphragm will be against its stop within the spring's chamber. When the engine is stopped and all of the non-return valves close, the spring pressure against the diaphragm will maintain the residual or holding pressure and overcome any slight seepage.
Within the data books for this system, it is shown that the critical time for maintaining these pressures, is between 5 and 20 minutes. After a journey, when the engine is switched off, the under bonnet temperature increases causing the fuel in the lines to heat and it attempts to evaporate.
Maintaining the pressure eliminates this problem and ensures a clean start when the vehicle has been standing with a hot engine.
Info pasted from Domain parking page
I am learning every day thanks for the web link volksacre , Chudd…
Have a look at this site and scroll down to CHECKVALVE the sixth box up on the left
http://www.users.bigpond.com/INTERJECT/KSITEPLN.HTM
it works!
Starts on the button when engine warm.
So, either I run a few more checks or I get a replacement thermotime switch.
Anyone got a part no. for the switch please?
The cost will decide how many more tests I do.
Peter.
does that mean that the time switch was staying closed and chucking fuel in when the engine was warm
I think so, thats what my books (Haynes, Bentleys and a Bosch one) list as the first reason for warm starting problems. It just floods the engine.
I guess it's listed first because it's cheapest and relatively easy to diagnose i.e, unplug it,
The next step off into accumalators, If it's the actual 5th fuel injector, leaky normal injectors etc which would be ???.
I haven't checked with a voltmeter whether voltage is still getting to the 5th injector which I might do before I buy a new switch.
I have read in Bentleys that it's possible to wire up the positive feed to 5th injector from the wrong terminal of the starter solenoid, which would give it permanent live, which would knacker up your mixture somewhat.
Peter.
