vacuum pipe with check valve / where from and how much?
(In Topic #143981)
It seems the valve with the two nipples for the vaccum and the pipe that goes to the master cylinder is one piece, does anyone know if you can just buy the valve and what the likely cost is - it looks expensive but I suspect a common part to break?
ETKA shows the description as: "vacuum pipe with check valve"
CHECK VALVE
I'm guessing the part number I need is this: 172611931C
Thanks in advance, Guy
R32GUY
1992 Rivage in Classic Blue Pearl "B16YUG" 2.0 TFSI, 6 Speed FWD with Quaife LSD, running on Air with sorted geometry and Eibach ARB's, G60 brake setup front and rear, 4x100 17" BBS LM's, Power Steering, Opening Quarter-lights, Mk2 electric recaros and the whole car trimmed by MJ Interiors in tan and Alcantara with a brown roof.
Couldn't private message you so hope you dont mind me tagging onto your post.
Basically I need the same check valve & pipe that you needed. Did you just take the part number to VW in the end?
Thanks,
James
