1.8 DX Surging idle
(In Topic #198639)
Looking for some help!
I'm new here, long time lurker though! Currently have a 1992 Scirocco Scala! I know it's no golf. But you guys seem to know the DX inside out. Information on this forum is immense.
The engine is 1.8i DX.
The problem I have is a surging idle. From about 600-1200. It's really consistent, and does it under load too. Hot or cold makes no difference either.
The car starts perfectly. There's no rust in the system.
I have checked every vac line, and replaced.
It has a new WUR and AAV. All ingnition parts are new originals. And timing is spot on.
I'm just totally lost now!
Sorry for the long post! Hope someone can point me in the right direction.
I'll post a video when I get home, as I'm not the best at explaining.
Thanks,
Matt
Last edit: by Matty_26
I'm mobile at this moment but I'm sure members will get back to you over the next day or two!
Sent from my mobile phone.
I guess what's happened is your idle control screw has come lose they have do rattle them selves lose as the rubber O ring perishes, the screw/bolt behind the throttle body near the bulk head try removing it and see what the o ring is like 7mm spanner is needed the try increasing the idle when the car is warm to 950-1000 rpm and see if that helps.
The revs are going up and down as the idle control valve is keeping the car running.
Picture of the idle control screw/bolt which someone tried to glue in on a engine I'm rebuilding.
I'm having a play with the car this morning, I'll check that 'O' ring! I'v been spraying carb cleaner everywhere to attempt to find leaks to no avail.
Adjusting the screw decreased and increased idle speed as expected, while the surging remained throughout this.
Ahh it's driving me mad!
First video upload to a forum, I hope it works!
Dropbox - VIDEO0013_01.mp4 - Simplify your life
What that tells me I don't know.
I haven't been able to look at my car! My appendix had to come out instead! Ugh. Once i'm fit again i will check and report back
Thanks again
I checked all wiring and cleaned connections. Made no difference.
I swapped my 'Topran' relay for vw number 18 and bingo. Perfect. Started better then it has in two years with no surging!
My only question now is, what is the correct relay. The current one doesn't have any markings at all. Doesn't work right either.
Any other brands to go for? Or is second hand VW best? If so, would anybody kindly give me the correct relay number.
Thanks,
Matt
VW relay number/VW part number/KAE part number/gsf part number
2 = 321906059D / 3.300.210 / 935VG0090 = no limiter (superceeded by 321906059E-F)
62 = 443907385B/321906059G / 3.300.220 / ? = 6.5k limiter?
63 = 321906059E-F / 3.300.210 / 935VG0090 = no limiter
65 = 321906059H / 3.300.230 / 935VG0080? = 6.5k limiter
earlier cars have the limiter in the rotor arm, later in the relay. you can have neither if you like, just make sure you dont over rev. so basically choose if you want one with limiter in or not then use the part numbers above
Many thanks for all your help John, and others who helped me. Much appreciated!
Matt
