Glad to hear you took on the job yourself!
The heater valve's top screw might be loose.  This prevents the arm from turning properly with the control cable.  Check the position of the lever on the valve shaft and then tighten the screw.
Did you mean to reply to a post rather than create a new thread? :dontknow:
