Unknown connector
(In Topic #200136)
thanks in advance
Unknown connector
it fires the 5th injector if you floor the throttle on a cold engine, which you shouldnt really be doing anyway!
rubjonny said
the plug pictured is the idle switch which controls the cold throttle enrichment along with a vacuum valve on the rear of the airbox. its only fitted to late mk1 cab/rocco injection engines so I'd not worry too much.
Yeah the car idles at a very low Rev range but has never cut out. There is no need to sort it and have it plugged back in?
