tt kit + race cam = madness????
(In Topic #80491)
thanks
ronan
turbo cars don;t like large amounts of overlap :wink:
would porting and polishing the head make any diference?
Idealy you need to lower the compression either by fitting differnt pistons, having your pistons machined down or havine the head chambers enlarged.
http://img65.imageshack.us/img65/2838/s5000021agm0.jpg
ronan
I would agree that porting will help . i never polish the ports when i tune 2 strokes cos it does affect the fuel atonomisation on the shiney walls , the fuel can litterally condesate and turn into droplets rather than a gas . at the moment tho ur experimenting so only ever change one thing at a time . id leave the head for the moment , just strip it down and clean it up and check all the tolerances .
Id look at sourcing a thicker copper head gasket and non stretch head bolts 1st . this will lower the compression and hold the head flat and prevent warping under high boost levels . possably try colder plugs aswell to avoid detonation . run a good fuel like optimax aswell .
If you can source a bigger oil cooler that would be a good move as the oil/ water coolers often break and mix the 2 . i dony know if u have a roller bearing or floating vein turbo but water/oil going in there is not a good thing !!
I think the 2nd bits to source would be a bigger oil cooler and plenty of lagging . most failers are temperature related so you wanna keep temperatures down .
One other thing to remember is more boost = more igntion retard, and therefore doesn;t necesarily mean more power. Mine will produce as much BHP on less boost, but that's another story.
Porting and polishing of the head: ummm, always a great debate on forced induction cars as the area to improve in theory is the exchust ports as air is forced in anyway so therefore not much improvmenet would be had on thsi side, but TT did do a ported head for the "Full house" kits as they were referred to.
Oil cooler: TT Kits always ran the Air cooler versions on the MK1's, but with an uprated mocal version - I can check my car if needs be for the number of rows etc etc.
Hope this helps. :wink:
if the sumps not dented its not low enough
standard origonal 82 mk1 jetta c for sale
