trouble starting from cold
(In Topic #139519)
hi John, thanks for that, im not all up with my vw's i just love the car. i will take a look tomorrow and look at those components. thanks again its good to get some advise from someone who knows there stuff.rubjonny said
check the thermoswitch in the front coolant flange. if the wiring has shorted that would make the 5th inj stick open. also make sure the thermoswitch is a big brown one, if its small white 2 pin you have a digifant ecu temp sensor fitted which would explain everything
also quick one, do you thing that could cause a small splutter when cold?
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
finally get the ign timing checked, and reset the idle and co after
