To rebuild or not to rebuild?
(In Topic #94715)
I'm doing a full restration of my golf and wonding on weather i should do a rebuild on the engine. I'v got the engine out and im rebuilding the head.
But i'm not sure if i should do the bottom end.
What i really need to know is:
a. is it worth doing while i got it out?
b. will there be any notiable improvments?
c. how much will it roughtly cost?
d. how hard is it?
e. roughly how meny hours would it take?
The engines a DX i think its only done 98,000
Many Thanks
James
1987 Golf Mk1 GTI 1.8 Cabrio
Life Member
but if it was me i would do it then you can sleep at night safe in the knowledge that you have done all you can if you don't and its on the brink of breakdown you will be kicking yourself, if engines out do it now
just my opinion.
James
cost me about hundred -hundred and fifty quid mate, the only expensive part was the oil pump and that was about 30 quid from gsf, rings are 27ish shells are cheap but dont forget to get a bottom end gasket set! as you wont beable to save the gaskets and you get rear main seals etc in it.
well worth doing mate as you will kick ur self if u dont and it starts knocking… smoking etc. real easy but i would go and buy one of them engine stands from machine mart mine cost 30quid or sumin plus vat u dont need the heavy duty one the bog standerd 3 wheeld one is spot on, this lets u put it on and spin it over and saves u rummegin about on the floor or in your shed struggling to lift it or hold it still.
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
