Ticking noise????
(In Topic #95977)
Ticking noise????
For some reason sometimes a ticking noise comes from my engine? It doesn't seem to vary with the revs though? Its also only really audible when the car is idle (sometimes not). It sounds like a quick ticking as if something is constantly ribbing or clicking against something (don't know if that makes sense?)
Anyone come across it before?
You need to have a listen, use a screw driver against various parts with your ear pressed to the end of the handle wot work out what part the noise is coming from - careful you don't get caught up in any moving parts whilst doing this though…
Any idea how much to fix?
turned out it was a loose exhaust bracket or summat lol
It comes and goes. WHen it comes though I lose a lot of engine power and it almost chugs if that makes sense?
Teneighty3009 said
Its def not the exhaust or anything.
Oil level/temp? Could simply be a glased gause on the pickup for the oil pump - a sump gasket, can of fuel system cleaner and some time spent on your back with a 10mm socket will sort that one out.
What you desribe sounds like pre-ignition or possibly even detonation so it could be caused by heat or a coked up head.
I'd suggest you get a competent mechanic to look at it - and make sure he sees the problem first hand - otherwise it'll never get resolved.
