thermostat temp
(In Topic #192677)
1.8 GTI DX engine
so it turns out I think my stat has packed up. Cool air blowing in the heaters and temp gauge not moving.
a parts supplier lists two different ones. Is an 88' the right one? I assume the plastic housing needs replacement at the same time?!
your gauge may sit slighty under or over from 1/2 depending as some gauge/sensor combos can be slightly off etc but basically once you get to the normal running temp of your car it shouldnt drop below that again
My thermostat got stuck open last winter and on the move (A roads at 50 mph ish) the oil would not heat above 80 degrees but it was freezing in the mornings but as soon as I stopped in traffic the oil temputure would go up.
Fitted a new thermostat, o ring and new coolant and been fine since.
more help required!! I have changed the stat, but the red light on the water temp keeps flashing. I changed the sender on the header rain but the light still flashes!! Any ideas welcome!!
